It is currently Sat Jul 19, 2025 7:14 pm
Post new topic Reply to topic  [ 165 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: Thicknessing help
PostPosted: Fri Apr 10, 2015 7:05 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Jimmyjames wrote:
murrmac wrote:
Jimmyjames wrote:
The boutique planes do work out of the box but they work far better if tuned up, just my opinion.
-j
I am curious as to exactly what "tuning" you have ever had to carry out on a Lie Nielsen or a Veritas plane, which I assume are the models you have worked with ). Be specific, give full details.
I refine every mating part to as close contact and even pressure as possible. I polish every part that incurs friction: sole, leading edges of cap iron, chipbreaker, et cetera. Pretty simple but every bit helps.
-j
I've done all that on Stanley and Record planes back in the day .... that is why I use Veritas and Lie Nielsen nowadays ... with Lie Nielsen bronze planes in particular there is no need whatsoever for pissing around trying to improve them ... any perceived improvement is an illusion... they function perfectly. All you need to do is sharpen the iron, set the mouth, and you are good to go.
PostPosted: Fri Apr 10, 2015 7:59 pm
Your mileage may vary.
-j
PostPosted: Sat Apr 11, 2015 1:07 am
murrmac wrote:
-j
I hope you don't mind me butting in here, but even Heirloom planes are manufactured to a specification and a cost, Lie Nielsen's are, I believe , to USA XX-X specs and soles should be flat to within 1 1/2 thou, and all 3 I have you couldn't get a 1.2 thou feeler gauge anywhere near under the edge of any of them on a granite surface plate, (or a blue cigarette paper!)
But, the 62 and the LN block soles were both slightly concave and the adjustable mouth plates were low one side, high the other (fractionally). Took me a while to find out, and I fettled about 5 Stanleys and a Faithfull no.4 before attempting to touch the 62.
It wasn't that much (< 1 thou, maybe aound 03.-0.5) but a sharpie revealed toe, mouth, and back end of the sole were not coplanar, and the sole behind the mouth was slightly concave. And the block's adjustable mouth plate in particular was not flush at one side. LA block was much the same. I honestly reached for my Faithfull instead of the LN block plane
Before I flattened the sole, I could get 1 thou or so shavings in pine, maybe 1.25 thou in hardwood, now that's down to 0.5 thou.
It was a pleasure to use from day one, but now it's a joy, same for the block.
PostPosted: Sun Apr 12, 2015 6:19 pm
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
I broke down and bought a Woodriver #4 1/2 today from Woodcraft. I took my kid down to check out some of the cool woodworking tools. They had an assortment of planes out for customers to try. The sales guy helped me adjust it right there at the store. I haven't checked the sole yet, but omg it's it sweet, right out of the box. It's now the nicest plane I own, next to an old Record #4. Back to the workbench...
These users thanked the author Glenn_Aycock for the post: dzsmith (Mon Apr 13, 2015 7:37 pm)
PostPosted: Wed Apr 15, 2015 11:05 am
Last Name: Lee
Country: Wales U.K.
Cablepuller, where in the UK are you? I have a drum sander.
PostPosted: Wed Apr 15, 2015 12:38 pm
Hey whiskywill in devon mate... might have organised something but thanks for offer
PostPosted: Thu Apr 16, 2015 6:28 am
Last Name: Lee
Country: Wales U.K.
Not far if you can swim, but a long way around. :(
These users thanked the author whiskywill for the post: Cablepuller (Thu Apr 16, 2015 11:31 am)
PostPosted: Sat Apr 18, 2015 10:41 am
Just a quick update. .. the wood is now thinned woop...
Took it to a mates workshop whos a french polisher.. he had a thickness planer but still no joy.. it would only take off an extra 1mm or so and it really didnt like the rosewood. .
So we used an electric planer to remove some major material. . The wood looked realy rough then with real big cut channels. . But he was still confident and we then turned to his belt sander and it worked a treat..
The wood is super flat and has no heavy scratches that i was worrying about
Its a real case of just getting stuck in and finding what works for you
Thanks for all the advice
PostPosted: Sat Apr 18, 2015 10:49 am
Get a thickness sander.....:)
PostPosted: Sat Apr 18, 2015 10:54 am
Love to but way to much money hesh
PostPosted: Sat Apr 18, 2015 10:58 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I'm surprised you don't get wood chips... those power planers are not precision instruments!
Typhoon Guitars
PostPosted: Sat Apr 18, 2015 11:02 am
No chips tai ..he worked with the grain .4mm each pass... like i said looked rough after but belt sander sorted out lines..
A really good plane or thicknesser would be preferable but costs dictate otherwise .. for now !!!
PostPosted: Sat Apr 18, 2015 11:08 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I'm not sure, but the problem I see is perhaps the machine isn't set up right or held in the right places. They often take aggressive bites and doesn't produce good finish so you're at a risk of either splintering your wood or making it too thin. I have seen people use them for roughing out wood carvings which is why I never used them myself. Even hand planes can be dangerous when improperly set up due to tear outs. They also have very limited bed length meaning if you didn't hold it right, you could gouge the wood too. I would only use it in straight grained wood and not anything with even a slight amount of figure.
Typhoon Guitars
These users thanked the author Tai Fu for the post: Cablepuller (Sat Apr 18, 2015 11:12 am)
PostPosted: Sat Apr 18, 2015 11:10 am
We all have a level of confidence when we have nothing at risk -- it was your wood. "Truly you got lucky" a hand power planer or even a stationary power planer is simply not the tool designed for this work. If you care to search you'll find many sad tales from those trying to use hand and power planers on veneer -- Cable you are done, so this post is for others.
Ken Cierp
PostPosted: Sat Apr 18, 2015 11:16 am
I agree ken got lucky .. i thought a good hand plane was the advice i was getting on here..
Idunno did say money was a big factor
PostPosted: Sat Apr 18, 2015 11:39 am
No luck yet at the car boot?
PostPosted: Sat Apr 18, 2015 11:40 am
No nothing last week colin... going again tomorrow though :)
PostPosted: Sat Apr 18, 2015 12:02 pm
[:Y:]
PostPosted: Sat Apr 18, 2015 5:32 pm
I just got a lunch box planner, and had good success getting a bunch of ebony plates down to 1/8" which seems to be the lowest the beast wanted to go. Much much faster than the drum sander. Any lower and I suspect the wood would be too floppy to work in there.
These users thanked the author Pmaj7 for the post: Cablepuller (Sun Apr 19, 2015 12:53 am)
PostPosted: Sat Apr 18, 2015 5:39 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Well, ok, if your blade is very sharp it may work. However as you got the thickness below 3/8" the piece must be fully supported with a backer board (and how to get that off after finishing with planing I have no idea). If the piece were to flex even in a small way, disaster will strike!
Typhoon Guitars
PostPosted: Sat Apr 18, 2015 7:54 pm
Thanks for the wise words of warning Tai fu. Of course sharp blades are a must for any kind of cutting.
This was my first experience with a power planner and I was sort of pushing the envelope. I did not use a backer board and I was able to get down to about .130" without any problems. Although that ebony was quite stiff. That might of had something to do with it.
All in all I think it was a very good investment for $75 (10" Ryobi) and we'll have it's place in my process.
PostPosted: Sat Apr 18, 2015 8:02 pm
Fyi I did a Gabon ebony B&S starting at .190" and a bunch of Macassar Ebony backs that were very rough off of some Indonesian's bandsaw. Even at .130 there was still some hit and miss, but I've used a couple sets of it before and it's so hard and dense my final thickness was about .075 so it was fine.
PostPosted: Sat Apr 18, 2015 8:09 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I think a properly sharpened Wagner Safe T Planer or similar should do a better job without ruining the wood. You can then follow it up with a thickness sander.
Typhoon Guitars
PostPosted: Sat Apr 18, 2015 9:02 pm
First name: D
Last Name: S
I've taken Mesquite down to 3/32 " with my thickness planer using a sled.
Trying to run wood with figure, knots, or wavy grain usually results in disaster.
I've had good results thinning small figured stuff using my oscillating spindle sander with a fence, but it takes forever.
For the electrics I build, my next tool purchase will be a jointer.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Apr 19, 2015 12:31 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Using double stick tape for thin stock on a carrier board helps, as does putting it through at a bit of an angle so that a corner contacts the planer blades first, instead of the entire leading edge.
Alex
These users thanked the author Alex Kleon for the post: Pmaj7 (Sun Apr 19, 2015 2:45 am)
